2410 Read Voltage loads UUT output
jacy77
Post by jacy77 » January 25th, 2019, 9:48 am
I inherited some LabVIEW SW that Reads the Voltage on a UUT.
When the 2410 is switched in (Relays) the UUT output is loaded down.
I put a 1.5 Battery in series with a another external Current meter, during measurement it draws 200mA.
I have attached an image of the VI.
What I am not sure about is what was in the original meter's *RCL 0.
I have another post on that topic.
Thank you, Jeff
2410 Read Voltage.png (48.26 KiB) Viewed 3686 times
Re: 2410 Read Voltage loads UUT output
Post by Andrea C » February 13th, 2019, 5:27 am
Probably has something to do with output off mode, eg, what happens when SMU blue light is off. Is this the condition underwhich you see the UUT loading?
