EMG connection to DAQ6510 Model 7703 Multiplexer Module
HALOBEAST999
Post by HALOBEAST999 » November 20th, 2019, 12:11 pm
This may be a simple question but I am having an issue connecting EMG electrodes to the Model 7703 Multiplexer Module for the DAQ6510. I have read the manual and have the diagram explaining the pins and channels. My issue is I am trying to use the DAQ for emg signal reading. In order to do this I have to use 2 active electrodes and 1 reference electrode. I need to be able to connect all 3 of these electrodes to one channel in order to read a signal. Is there a way to have 2 HI and 1 LO for a single channel?
Re: EMG connection to DAQ6510 Model 7703 Multiplexer Module
Post by Andrea C » November 21st, 2019, 3:04 am
No, that’s not what the 7703 and DAQ6510 can do. The 7703 provides multiple channels of HI and LO which will be routed to the voltmeter input of the DAQ6510 when a channel is closed.
For three electrode EMG, seems you need some small amplifier circuit. The output of that could be monitored with the DAQ6510.
Return to “Data Acquisition Accessories”
