[MDO4104] need VISA command set to pull data in CSV in real time.
4001jh
Country: South Korea
Post by 4001jh » December 1st, 2021, 6:38 pm
Hi.
Is it possible to get waveform data from MDO4104-6 in CSV?
; I want to record waveform for few hours.
using VISA, I can get screen image.
but I need raw data and getting image is slow. :?
Thanks.
Re: [MDO4104] need VISA command set to pull data in CSV in real time.
Post by Andrea C » December 3rd, 2021, 1:42 pm
Try this utility software that uses NI VISA. You could also use NI IOTrace tool and capture the SCPI commands.
https://forum.tek.com/viewtopic.php?f=571&t=140451
4001jh
Post by 4001jh » December 8th, 2021, 12:07 am
I've installed that program. and I can connect my scope and PC.
; at Console menu.
; *IDN?
; TEKTRONIX,MDO4104-6,C012555,CF:91.1CT FV:v2.94
But at hardcopy screen, There's nothing. and nothing moves.
Save As and Get Hard Copy buttons are not found.
Can I get a manual like quick start guide?
I tried to change screen size of the program and screen zoom and layout setting of windows10.
windows text size in accessibility is also minimum (100%).
But the two buttons are not comming.
; I could not tried to use IO trace.
Thank you.
4001jh.
Post by Andrea C » December 8th, 2021, 4:46 pm
Sorry you have that difficulty.
In meantime, for MDO4K try this post instead:
viewtopic.php?t=138684
4001jh
Post by 4001jh » December 9th, 2021, 6:30 pm
Thanks. It seems the code works.
I've changed two lines.
- import visa -> import pyvisa
- visa_address
4001jh
Post by 4001jh » December 13th, 2021, 12:50 am
Dear Andrea C
How can I get data from multi channels? (from ch1 to ch4)
Thanks to your reply ('viewtopic.php?t=138684').
Reading a channel was easy.
But I still have a problem to expand source range.
scope.write('data:source CH1') # this works.
## event status register: 0b00000000
## all event messages: 0,"No events to report - queue empty"
scope.write('data:source CH1-CH4') # this doesn't work
## event status register: 0b00100000
## all event messages: 141,"Invalid character data; Unexpected input following character data; data:source CH1-"
Thanks.
