Two channels measurements with 2182A
2182 Series Support
Malinaric
Country: Slovak Republic
Post by Malinaric » May 3rd, 2012, 6:50 am
In the test all 4 input clips were connected together. The following program gave the erroneous results in CH1. Please tell me where I made the mistake.
PRINT #1, "*rst"
PRINT #1, "trac:clear"
PRINT #1, "sense:volt:chan1:rang 0.1"
PRINT #1, "sense:volt:chan2:rang 0.1"
PRINT #1, "sens:volt:nplc 1"
PRINT #1, "syst:faz off"
PRINT #1, "syst:azer off"
PRINT #1, "sens:volt:chan1:dfil off"
PRINT #1, "sens:volt:chan1:lpas off"
PRINT #1, "sens:volt:chan2:dfil off"
PRINT #1, "sens:volt:chan2:lpas off"
PRINT #1, "samp:coun 2"
PRINT #1, "rout:scan:int:cco 1"
PRINT #1, "rout:scan:lsel int"
PRINT #1, "trig:del 0"
PRINT #1, "trig:coun 300"
PRINT #1, "trig:sour tim"
PRINT #1, "trig:tim 0.1"
PRINT #1, "trac:poin 600"
PRINT #1, "trac:feed:cont next"
PRINT #1, "disp:enab off"
PRINT #1, "init"
PRINT #1, "*wai"
PRINT #1, "disp:enab on"
PRINT #1, "trace:data?"
LINE INPUT #1, rd$
Return to “Nanovoltmeters”
