Series 3700 System Switch/Multimeter Firmware
Locked
Dave W
Post by Dave W » June 8th, 2010, 1:23 pm
Download links for Series 3700 firmware can be found below. Please also visit the Support Page of www.keithley.com and type in 3706 into the search box and select Firmware from the drop down and click the search button.
Firmware Downloads:
Current Version:
Download 1.41c (released January 10, 2011)
Previous Versions:
Download 1.40k (released June 8, 2010)
Download 1.32a (released March 8, 2010)
Download 1.31a (released June 23, 2009)
Installation Instructions:
For the most complete firmware installation instructions, please refer to the release notes included with the firmware update. These may include additional details such as upgrading the instrument's OS.
Quick Instructions
To install Series 3700 firmware simply place the downloaded .CAB file in the root folder of a USB thumb drive then insert the drive into the front panel of the 3706. If the downloaded file was a .ZIP file, extract from the Zip file the .CAB file before copying it to the USB thumb drive. From the front panel of the 3706 press the MENU button then scroll right until the option UPGRADE is highlighted. Press ENTER. From the Upgrade Unit? menu select YES or PREVIOUS then press ENTER. The upgrade process will commence. Do not use or power off the unit until the upgrade process is complete and the unit has restarted.
Locked
