change current during delta mode
6220, 6221 Current Sources
hachiko
Country: China
Post by hachiko » July 4th, 2013, 7:39 pm
Can I change current value during delta armed (6221+2182)?
Re: change current during delta mode
Post by Dale C » July 8th, 2013, 7:33 am
Yes.
On the front panel of the Model 6221 press CONFIG, then let go.
Now press DELTA.
Select I-HIGH, press ENTER.
Select the high value of current and press ENTER.
The opposite polarity of the current will be selected as the I-LOW current automatically.
Press EXIT.
Now run the Delta mode as usual.
From remote control send the following command to change the I-HIGH value to 10mA.
SOUR:DELT:HIGH 1e-2
That should do it.
hachiko
Country: China
Post by hachiko » July 11th, 2013, 7:20 am
Maybe I didn't state my question clearly.
My question is: for remote control during Delta Arm status, can I change the current without exiting Delt mode ?
Return to “Current Sources”
