Script for sweeping voltage forward and reverse
Shaleen
Post by Shaleen » July 12th, 2013, 10:50 am
I am using Keithley 2602a instrument and I needed to write a TSB script to measure hysteresis in current by applying sweeping voltage from an initial value to end value and then back to initial value with no time lag during transition from forward to reverse sweep measuring current according to the number of points entered.I wrote the following script-
--TODO Please insert code here.
function hysteresis(smu,startvalue,endvalue,points,compliance,scrdelay)
--Sweeping voltage first increasing then decreasing, forming a loop on selected smu channel and measure current.
--Measure and return current for given corresponding voltages in a tabular format.
--Pass parameters:
-- smu is the smu channel selected for the test (A or B); smub is default
-- startvalue is source loop voltage minimum value; -1V default
-- endvalue is source loop voltage maximum value value; 1V default
-- points are the number of current measurements to be made; 100 default
--default to smua if no smu specified
if smu == nil then smu = smub end
--prompt for input parameters if missing from list
if startvalue == nil then
startvalue = display.prompt("0.000E+00", " Volts", "Enter Minimum value of loop voltage.", -1,-20,20)
end --end if
if endvalue == nil then
endvalue = display.prompt("0.000E+00", " Volts", "Enter Maximum value of loop voltage.", 1,-20,20)
end
if points == nil then
points = display.prompt("000", " Enter the number of measurements to be made", 100,100,200)
end --end if
if compliance == nil then
compliance = display.prompt("00.000", " Enter the Compliance current value", 1,100E-9,1)
end --end if
--wait before making measurement
if srcdelay == nil then
srcdelay = display.prompt("000", " Seconds", "Enter Source Delay.", 0,0,20)
end --end if
delay(srcdelay)
smu.source.limiti = compliance
--Configure source and measure settings
smu.source.func = smu.OUTPUT_DCVOLTS
function clearBuffers()
smu.nvbuffer1.clear() --clear smui nvbuffer1
smu.nvbuffer2.clear() --clear smui nvbuffer2
end
function setsmu1()
smu.trigger.source.linearv(startvalue, endvalue, points)
smu.trigger.measure.i(smu.nvbuffer1)
smu.trigger.source.action = smu.ENABLE
end
function output1()
smu.nvbuffer1.collectsourcevalues=1
smu.measure.count=1
smu.source.output = smu.OUTPUT_ON
smua.source.output = smu.OUTPUT_ON
smua.trigger.initiate()
waitcomplete()
printbuffer(1, 150, smu.nvbuffer1.readings)
printbuffer(smu.nvbuffer1.sourcevalues)
print("*********************")
smu.source.output = smu.OUTPUT_OFF
smua.source.output = smu.OUTPUT_OFF
end
function setsmu2()
smu.trigger.source.action = smu.DISABLE
smu.trigger.source.linearv(endvalue, startvalue, points)
smu.trigger.measure.i(smu.nvbuffer2)
end
function output2()
smu.nvbuffer2.collectsourcevalues=1
smu.measure.count=1
waitcomplete()
printbuffer(1, 150, smu.nvbuffer2.readings)
printbuffer(smu.nvbuffer2.sourcevalues)
end
clearBuffers()
setsmu1()
output1()
setsmu2()
output2()
end --function Hysteresis()
the program was built successfully
the program was run and the following parameters were passed-
hysteresis(smu,-5,5,150,0.01,0)
to which I got the following output-
9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37, 9.91000e+37
5038, SMU B: Index exceeds maximum reading
-350, Queue full error
Please help me.I am a fairly new user of TSB, I don't know where I am going wrong.
I need voltage and the corresponding current measurement value in a tabular format.
-Thanks
Re: Script for sweeping voltage forward and reverse
Post by Andrea C » July 17th, 2013, 8:33 am
Hi Shaleen,
You've not completely setup a trigger model based measurement, so this is why it's not quite doing what you want.
If you have version E02 of the Test Script Builder software, check out the examples that are distributed with the application.
In particular, look at the KE26XXB_DC_Sweeps.tsp file located in the KE26XXB_Example_Scripts project folder.
There is a DCSweepVList() function defined in that file. By passing a voltage list that represents your forward and reverse sweep, you'll be able to do the hysteresis test.
Andrea
Users browsing this forum: Bing [Bot] and 0 guests
