connect 6221 to several 2182 at the same time
2182 Series Support
czhangfdu
Country: China
Post by czhangfdu » October 16th, 2013, 9:13 am
I was wandering if 6221 can be connected to several 2182 at the same time for delta mode?
Thanks!
Cheng
Kenneth P
Re: connect 6221 to several 2182 at the same time
Post by Kenneth P » October 21st, 2013, 8:49 am
Hello Cheng,
It is not possible to connect more than one 2182A to the 6221 while using Delta mode.The Delta mode operation uses the 6221 as the master and readings are taken and displayed using the 6221 and it is designed to only communicate with only one 2182A
Return to “Nanovoltmeters”
