Direct Data storage from 2657
Model 2657A
ramyacs55
Post by ramyacs55 » November 12th, 2013, 10:02 pm
I need to store the buffer values of 2657A SMU into USB in either csv format or in excel format. What commands must I include in the script inorder to obtain the above.
Re: Direct Data storage from 2657
Post by Andrea C » November 13th, 2013, 8:04 am
There is a utility function called savebuffer() in the nvmemory of the instrument.
Call it with something like:
savebuffer(smua.nvbuffer1, "csv", "my_file_name.csv")
Be sure that you have first inserted a USB thumb drive into the data port of the 2657A.
Alternately, you can customize your own implementation of these io.x methods for file I/O.
If you want to examine the source implementation of the savebuffer() function, you can get a source code listing by using the Instrument Console Window of Test Script Builder:
Andrea
