Firmware Update Problems
DynaTim
Post by DynaTim » December 5th, 2013, 4:41 am
I have a 2100 that needs a firmware update from V1.02 to V1.08. I have downloaded the appropriate compressed file with the following items:
- KI Model 2100 Firmware Revision Update Readme (June 2007).pdf
- DmmUpdate.exe
- 2100 Release notes rev1_08
- 1232_K01.bin
- 5407_K1.08.bin
I have installed on my PC:
visa540_full.exe
NIMax.exe
KI_TOOL.exe
My OS is Win7, and I have run the DmmUpdate application as administrator.
Upon following the directions outlined in KI Model 2100 Firmware Revision Update Readme (June 2007).pdf, between steps 5 and 6 (step 5 is when you are supposed to select which firmware to update, front end or processor - step 6 is after it has been updated) I get this indication:
"5407_K1.08.bin" firmware update failure! Please recycle power on
instrument now and Try again.
After instrument power is recycled, if you want to update another binary
file, please press the "Continue" button, otherwise press the "OK" button
to exit.
Any ideas? Thanks!
Stuart M
Keithley
Keithley
Re: Firmware Update Problems
Post by Stuart M » December 6th, 2013, 11:19 am
Not sure what your problem is.
See if you can upgrade to 1.05.
If not, I believe 1.06 is also posted -.
Then retry upgrade to 1.08.
DynaTim
Post by DynaTim » December 18th, 2013, 10:13 am
Thanks for the suggestion!
I tried all 3 available versions (5, 6 and 8), and all three gave me the same indications (replace text with applicable firmware version):
"5407_K1.06.bin" firmware update failure! Please recycle power on
to exit.
I did try updating the front end as well (after the other failures) and every version said the software I was trying to install was older than the currently installed version. I am guessing whats on there must be the same as what I am trying to install.
For the front end, I am trying to install:
1232_K01.bin
And my version is:
01-01
. I am guessing they are one and the same?
Stuart M
Keithley
Keithley
Post by Stuart M » January 6th, 2014, 1:44 pm
Hmm...try the flash program I have posted on our ftp site:
Go to the Keitley ftp site.
ftp:://ftp.keithley.com
user name = kicust
password = w3lc0m3
(This spells welcome but the vowels are integers).
Look for the folder "2100"
Then down load the zip file there and extract all.
Then use the nochk exe file I have supplied and flash the instrument with the 5407 file in that directory too.
Hope you get better results!
dburkhard
Post by dburkhard » April 6th, 2014, 9:23 pm
I am experiencing the exact same problem but I can't seem to access the ftp site to try the suggested solution. Is it still active?
Daryl B.
Stuart M
Keithley
Keithley
Post by Stuart M » April 7th, 2014, 7:40 am
Yes the site is still active, please try again.
And the zip file you need is in the 2100 folder...
dburkhard
Post by dburkhard » April 7th, 2014, 6:16 pm
Thanks, the problem turned out to be my firewall. But I still am having the same problem. I get a "5407_K1.08.bin" firmware update failure! Please recycle power on
instrument now and Try again. This is the same as the original flash updater. I tried several different USB cables and ports with no change. Please let me know if there is another option.
Daryl B.
Stuart M
Keithley
Keithley
Post by Stuart M » April 8th, 2014, 8:16 am
Hmm...what firmware is on your instrument now?
Can you send me the *idn? string from your instrument?
dburkhard
Post by dburkhard » April 8th, 2014, 5:45 pm
The *IDN? string is: USB0::0x05E6::0x2100::1194357::INSTR
The firmware revision is: 01.05-01-01
Stuart M
Keithley
Keithley
Post by Stuart M » April 11th, 2014, 9:02 am
I have placed a newer version of the update program on our ftp site.
Then download the zip file there and extract all.
Please download and let me know if this updates your 2100 correctly.
dburkhard
Post by dburkhard » April 11th, 2014, 6:27 pm
Stuart,
It worked perfectly! Thanks for all the help.
Daryl B.
Stuart M
Keithley
Keithley
Post by Stuart M » April 15th, 2014, 9:16 am
Glad to hear.
You are quite welcome.
The 1.08 firmware with the new DmmUpdate program is now posted - for all to download on our website.
http://www.keithley.com/support/data?asset=54606
riccalam
Country: Italy
Post by riccalam » January 7th, 2016, 7:24 am
Stuart,
the link not work. I have download 1.08 firmware pack from Tektronix website but I found the same problem descript above. I mean that depends from the DmmUpdate_KI.exe ver. 1.05 dated 3/2/2011.
Please can you send me a working link for download the last DmmUpdate_KI.exe utility?
Many thanks in advance for your assistance.
Stuart M
Keithley
Keithley
Post by Stuart M » January 8th, 2016, 3:08 pm
We have moved web servers, here is the main download website to use:
http://www.tek.com/downloads
And for your convenience, here are the latest links to download Model 2100 firmware versions 1.08, 1.06, and 1.05:
Model 2100 Firmware Files revision 1_08
http://www.tek.com/product/2100-120-sof ... vision-108
Model 2100 Firmware Files revision 1_06
http://www.tek.com/software/model-2100- ... vision-106
Model 2100 Firmware Files revision 1_05
http://www.tek.com/software/model-2100- ... vision-105
